i have made a survey for layers in the grounds every layer is a repeat. i want to add rows in my excel when a survey has been added but it isint working. has annyone done this and an share pic of flow?
i heard vers 3.11 should support this flow.
I've been having the same problem, did you ever have any luck getting this figured out @MelisaGustafsson ?
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
