I have created an Experience Builder with the intent to have the map on one side and the survey on the other using the Survey123 widget.
This works flawlessly and I love it, however I've run into a problem when I need to add a French version of the Survey. Despite setting the "default_language" in the survey, which changes my labels, the buttons (Next, Back, Submit, Page 1 of 4) do not change to French on default.
I would prefer it just to be French and not require giving the user an option (split surveys), in part due to the fact the language selection menu does not appear properly in the Survey123 widget.
Is there a way through Experience Builder to set the language on the survey? Similar to using the custom URL scheme "lang=fr" or a setting that I'm missing somewhere?
