I configured the Search Functionality in Web Map using "Find Location" and added Query layers. And When I search in ArcGIS Field Maps I am getting results as "No Title" Records. The layer Configured with Display Field and Configured proper title for Pop up using "Configure Pop up " in Web Map. Please find Attachment for more Info
How do you choose what field is the "Title" field for each related record? I know you can set the Form Title of the related table, but I do not see where to chose the field for each record.
I was having the same issue. I checked everything and finally found that I needed to update the Title in the AGOL map (not Field Maps) under the Tables, not Layers. In the left pane I selected Tables, Popups, and updated the Title in that location.
Please make sure that the field chosen as the "Title" field has populated values. If the field value is blank/NaN, the title can be shown as "No Title".
Do those same records in your search result list show correct titles in Map Viewer?
I'm having the same issue. No matter where I set the title... either in the map viewer for the popup... and that's the title for each feature, not the generic title for the popup... or if I set the title in Field Maps, as @jkarmon is showing in her screen shots, I still get "no title". In other words, I can't seem to do anything that make that not say "no title".
I'm not having this issue on parent features (in my case a point hosted layer), but I AM having "No Title" issues (see second image) on related table records using a smart form. (The table has a title set in the pop-up's configuration - see first image). This issue is occurring on Field Maps on both iOS and Android devices using version 21.2.0 last updated Apr 7, 2021. Anyone else experiencing this? Is there a workaround?
The layer's pop-up title can be configured in ArcGIS Online map viewer using "Configure pop-ups".
If not configured, the default is going to be "No Title".
Yes. The popup title can be configured in ArcGIS Online map viewer using "Configure pop-ups".
I am not alix but republishing does nothing to solve this. Merely keeps showing the same problem.
Hi alix , please republish the service and re-configure the pop up with title . It should be working
I'm having an issue somewhat similar. Once in FM and I'm adding features- why are they all saying 'No Title'? Is there a configure pop-ups etc. I can set to have this name be one of the fields user has entered?
I'm having an issue somewhat similiar. Once in FM and I'm adding features- why are they all saying 'No Title'? Is there a configure pop-ups etc. I can set to have this name be one of the fields user has entered?
I agree I am seeing this same error. I configure inside of the Settings in the Web Map to search my layer. However after you type in your search in Field Maps app, it gives a result entitled "No Title" no matter what you type. Why isn't it showing the actual attribute that is being searched?
Hi vijaybadugu,
Sorry you are having this issue. I think this issue would be best resolved if I could see the map, would you be able to share you map with the user arcgisfieldmaps?
Thank you,
Alix
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
