Hi everyone
I want to display multiple points in a map using array
here is my code
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
<title>ArcGIS API for JavaScript Tutorials: Create a JavaScript starter app</title>
<style>
html, body, #viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.15/esri/themes/light/main.css">
<script src="https://js.arcgis.com/4.15/"></script>
<script>
// My Array
var locs = ["51.38254, -2.362804", "51.235249, -2.297804", "51.086126, -2.210767"]
require([
"esri/Map",
"esri/views/MapView",
"esri/Graphic",
"esri/layers/GraphicsLayer",
"esri/geometry/Multipoint",
"esri/layers/FeatureLayer",
"esri/geometry/Point",
"dojo/domReady!"
], function(Map, MapView, Graphic, GraphicsLayer,
Point) {
var map = new Map({
basemap: "dark-gray"
var view = new MapView({
container: "viewDiv",
map: map,
center: [46.738586,24.774265], // longitude, latitude
zoom: 6
var graphicsLayer = new GraphicsLayer();
map.add(graphicsLayer);
// create a point
var Point ={
type: "point",
longitude: 48.738586,
latitude: 24.774265
var simpleMarkerSymbol = {
type: "simple-marker",
color: [46, 204, 113 ], // Green
outline: {
color: [255, 255, 255], // white
width: 1
//*** ADD ***//
// Create attributes
var attributes = {
Name: "My point", // The name of the
Location: " Point Dume State Beach", // The owner of the
// Create popup template
var popupTemplate = {
title: "{Name}",
content: "Test <b>{Location}</b>."
var pointGraphic = new Graphic({
geometry: Point,
symbol: simpleMarkerSymbol,
//*** ADD ***//
attributes: attributes,
popupTemplate: popupTemplate
graphicsLayer.add(pointGraphic);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
