I'm trying to delineate watershed and sub watershed using Arc Hydro.
I created watershed in the following procedure.
- Dem Manipulation (Fill Sinks)
- Flow Direction
- Flow Accumulation
- Stream Definition
- Stream Segmentation
- Catchment Grid Delineation
- Catchment Polygon Processing
- Drainage Line Processing
- Adjoint Catchment Processing
- Drainage Point Processing
However, the output of Catchment Polygon Processing different from the shape of DEM .(Please Look at the picture. The red line is the out put of catchment polygon process, and the background picture is DEM.)
I don't know how to get the output in Catchment Polygon Processing which is the same shape of DEM.
Can someone please help me how I can do this?
Thank you.
