Hi there,
I've added a layer to my Map, and it appears as a layer in my 'Layer list' widget in the application I've built through Web AppBuilder. However, when I try building a Query on this layer, it doesn't appear and so I can't use it to build my query. I know that I can pull the layer in from Portal, but then you can't select the results to appear like your pop-ups, which is very restrictive.
Has anyone else had this issue and knows why it happens? More importantly, how do I fix it?
The layer has c150K elements, but it displays at full resolution quite happily, so I don't think it's a size issue. I'm using Portal V 10.8.
