Hi All,
Does anyone have a working example of using the q:queryparameter URL parameter to launch Survey123 (Windows or iOS/Android) [edit] from a pop-up and open an existing survey for editing? So far my attempts get me as far as the Inbox, but I cannot load the form with a specific record to edit. I’m assuming that this parameter can be used this way!
The q:queryparameter "Queries the feature layer for an existing record. It can be used to retrieve content that is not on the device." So I should be able to have nothing preloaded in the Inbox.
The example in Integrate with other apps is q:objectIds=12. I assume this could be q:objectId={objectID} (not sure if 'objectIds' is a typo in the web page?) or even better q:globalID={globalID}.
This is what I have so far and it doesn't work. I have tried a few variations around these with no success (I did also try ObjectID).
I had no issue with creating the URL to open a specific survey in edit mode in the web. The app version is just not working for me. If anyone could provide a working example or point out what I am doing wrong I would very much appreciate it.
Thanks, Jamie.
