I'm having problems with a stand-alone script that uses the FeatureClassToGeodatabase function. When executing it in the IDE, the print statement executes with the output below which looks correct.
The code executes fine within the AGP python window, but doesn't work when executing from PyCharm.
I'm not new to executing stand-alone scripts, but I can't figure this out!
homeDir = r"E:\ArcGIS\Projects\del_testingMDR"
fileName = r"del_testingMDR.aprx"
aprx = arcpy.mp.ArcGISProject(os.path.join(homeDir, fileName))
aprxMap = aprx.listMaps("Map")[0]
def AddSHPtoGDB(r):
:param r: function is called during iteration over region list. r is a single region string
:return:
input_files = []
for wx in wx_vars:
for file in os.listdir(ndfd_output + "/" + r):
if file.endswith(".shp"):
if file.lower().startswith(wx.lower()):
input_files.append(os.path.join(ndfd_output, r, file))
in_features = input_files
out_location = r"E:\ArcGIS\Projects\del_testingMDR\wwa_Import.gdb"
arcpy.FeatureClassToGeodatabase_conversion(in_features,out_location)
print("adding {} to {}".format(in_features,out_location))
in_features
['C:\\ndfd\\degrib\\output\\conus\\WWA_12011800.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12011900.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12012000.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12012100.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12012200.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12012300.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12020000.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12020100.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12020200.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12020300.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12020400.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12020500.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12020600.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12020700.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12020800.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12020900.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12021000.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12021100.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12021200.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12021300.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12021400.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12021500.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12021600.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12021700.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12021800.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12021900.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12022000.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12022100.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12022200.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12022300.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12030000.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12030100.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12030200.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12030300.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12030400.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12030500.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12030600.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12030700.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12030800.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12030900.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12031000.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12031100.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12031200.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12031300.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12031400.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12031500.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12031600.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12031700.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12031800.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12031900.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12032000.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12032100.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12032200.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12032300.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12040000.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12040600.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12041200.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12041800.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12050000.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12050600.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12051200.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12051800.shp', 'C:\\ndfd\\degrib\\output\\conus\\WWA_12060000.shp']
out_location
'E:\\ArcGIS\\Projects\\del_testingMDR\\wwa_Import.gdb'
