I have a basic print example based on http://help.arcgis.com/en/webapi/javascript/arcgis/jssamples/widget_print_esri_request.html, but I have changed out the webmap for a standard JS map with arcdynamicservicelayers etc. This works just fine in Firefox. When I try the sample code in IE 8, it doesn't look to load the esri.dijit.Print I created. Instead, looking at the IE Developers Tools, I'm getting errors for 'Object doesn't support this property or method' . The Print button I expect to see never loads and neither does my map. I've played with a couple of different version of the API, but that doesn't seem to help. This must work in IE. Maybe it's something small I just haven't spotted yet? <!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Print Digit Sample</title> <link type="text/css" rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dijit/themes/claro/claro.css"> <link type="text/css" rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } h3 { margin: 0 0 5px 0; border-bottom: 1px solid #444; padding: 0 0 5px 0; text-align: center; } #map{ margin: 0; padding: 0; } #printDiag { background: #fff; border: solid; border-width: 1px; color: #000; font-family: arial; height: auto; right: 30px; top: 30px; margin: 5px; padding: 10px; position: absolute; width: 300px; z-index: 40; #note { font-size: 80%; font-weight: 700; padding: 0 0 10px 0; } #info { padding: 10px 0 0 0; } </style> <script type="text/javascript"> var dojoConfig = { parseOnLoad: true }; </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2"> </script> <script> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.arcgis.utils"); dojo.require("esri.dijit.Print"); var pathName = "https://myserver.gov"; var printUrl; printUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task"; function init(){ esri.config.defaults.io.proxyUrl = "proxy/proxy.ashx"; spatialReference = new esri.SpatialReference({ wkid: 102100 }); startExtent = new esri.geometry.Extent(-10723197, 4186914, -9829190, 4992866, spatialReference); map = new esri.Map("map", { extent: startExtent }); countyLayer = new esri.layers.ArcGISDynamicMapServiceLayer(pathName + "/ArcGIS/rest/services/BaseMap/county_simple/MapServer", { id: "countyLayer" }); map.addLayer(countyLayer); createPrintDijit("This is my Title"); } function createPrintDijit(printTitle) { var layoutTemplate, templateNames, mapOnlyIndex, templates; // create an array of objects that will be used to create print templates var layouts = [ { "name": "Letter ANSI A Landscape", "label": "Landscape - PDF", "format": "pdf", "options": { "legendLayers": [], // empty array means no legend "scalebarUnit": "Miles", "titleText": printTitle , "copyrightText": "Missouri Office of Geospatial Information" } }, { "name": "Letter ANSI A Portrait", "label": "Portrait - PDF", "format": "pdf", "options": { "legendLayers": [], "scaleBarUnit": "Miles", "titleText": printTitle , "copyrightText": "Missouri Office of Geospatial Information" } } ]; // create the print templates, could also use dojo.map templates = []; dojo.forEach(layouts, function(lo) { var t = new esri.tasks.PrintTemplate(); t.layout = lo.name; t.label = lo.label; t.format = lo.format; t.layoutOptions = lo.options; templates.push(t); }); var printer = new esri.dijit.Print({ "map": map, "templates": templates, url: printUrl }, dojo.byId("print_button")); printer.startup(); } dojo.ready(init); </script> </head> <body class="claro"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"> <div id="printDiag" > <h3> Creating Map Output </h3> <div id="info"> <div id="note"> To Use: Click the print button to choose either Landscape or Portrait format. <br><br>Once your PDF is generated, the print button will change link that says Printout. Click it to view your PDF. </div> <!-- that will be used for the print dijit --> <div id="print_button" ></div> </div> </div> </div> </div> </body> </html>
