I have uploaded a feature parcel layer data set to arcgis online. I have selected the sync setting and made sure it is available for offline use. However when creating a map with the layer and sharing the map I can not get the map to show up in the collector app. Is there some sort of parcel limit or something? ant tips?
Thanks.
Hey Charles,
Is there are least one feature within that map that is editable? Collector is intended for editing purposes while Explorer is for viewing only. Collector can only see Web Maps which have at least one feature in them that is editable. While in your Web Map, select the small arrow next to the parcel layer to expand its menu and check to see that editing is enabled. If you do not want the parcel layer to be editable consider adding a "Notes" point feature that is editable or just use Explorer. Hope this helps, let me editing is enabled and you are still unable to see the web map in Collector.
Yep. That did the trick!
Thank you
