I would like to be able to change the order of the vertexes of a polygon. I often find myself wanting to edit a polygon using the sketch tool but needing to edit from a segment that is not at the end of the initial digitizing. This could also simply be the ability to insert vertices via sketch instead of with the edit tool. By selecting a line segment and the appropriate function from the drop down you could begin sketching and the new vertices would be inserted along the new line.
This is available in ArcGIS Pro as of the 3.2 release and works as described in the Help
Connectez-vous pour publier, suivre du contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
