One shortcoming in Insights for ArcGIS is that it does not seem to honour the region settings that are set in the Online Organization Enterprise Portal. This is somethign that shows Up annoyingly when you geocode or Enrich data. If the region settings in my organization/portal are set to “Canada” the geocoder and enrichment region setting should default to that. This could also be accomplished with a settings or options UI for Insights.
Chris
Connectez-vous pour publier, suivre du contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
