The &autoplay parameter when using the "kiosk" mode should have the option to have the slow (or fast) mode by default (or even a speed value parameter). Each refresh of the page makes it go back to "Medium" this can be frustrating. Can this parameter have more options please?
Yes please, this would be very helpful.
@MelissaBrooks Sorry, we didn't see this idea earlier because it was posted to the ArcGIS Online ideas board. I just moved it to the ArcGIS StoryMaps ideas board.
This is already available. You can use the "speed" parameter in any bookmarks you have to set the speed for autoplay. Slow = 1/2x, medium = 1x, and fast = 2x. Be sure to also include the "play" parameter as well. For example:
https://storymaps.arcgis.com/stories/c87bc0a59c0144008e25d50a5dd1b192?play&speed=slow
After autoplay started, the speed can also easily be updated from the control panel that appears when you move the mouse.
Connectez-vous pour publier, suivre du contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
