Wanted to make a tool that had parameters that allowed you to query a certain range of dates and export only those records that fall within those dates. You can do this manually through the SQL expression text box but it would be cool to see if when you chose from a date field in the query that you could show a calendar popup. This would make it easier for a user to put in date parameters.
Thank you for your submission, and apologies for the very late response. Your post was only recently redirected to the correct ideas exchange for Python/ArcPy ideas.
You may have already noticed your request is already implemented in ArcGIS Pro for parameters with a date type for some time:
We are closing this request now as implemented.
Connectez-vous pour publier, suivre du contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
