Hello everyone
I'll have to deploy an arcgis entreprise on a server. However ... first things first! I need a server and I do not all information I need to dimension the hardware. And I might be completely off as it is a premiere for me to deploy that kind of inrfastructure. I need advice from experienced people because I'm a bit lost with the ESRI documentation
The only constraint is a single machine deployment
Basically, I'll need to deploy in a first step arcgis server, webadaptor, portal, Image server.
So if i believe
ArcgisServer 10.7 (or 10.8) 4 cores- RAM:8GB
Portal For Arcgis: 2 cores- RAM:8GB
Image Server: 2cores RAM:8GB
And the system should be scalable to incorporate arcgis geoevent server at a later stage
Geoevent server 2 cores- RAM:8GB
In terms of storage I'll start with a 2*2To raid 0 mounted
As a minimum in development I should require 10 cores-32GB RAM 2*2To drives.System should be scalable to 64GB RAM. Physical storage does not need to be scalable yet.
I do ignore the caches needed.
I do ignore connectivity requirements.
However I found such a configuration simply overkill at a first glance. Am I right? Or is it not engouh?
