I would like to see a widget created similar to the distress appearance that allows the creator of the survey question to configure the following options:
I have the same need.
The Distress widget is brilliant as extremely visual ; being able to customize it would make it more powerful and widespread. The colors used by default have implicit meaning (green: good ; red: bad / grren : low ; red: strong, etc), which is not always a good match with the numbers associated to them (by default: red: large value).
I would like to use a version of Distress that is low value = red = bad/low and high value = good = green. The use case is to register tree helath state or damage asseessment.
The likert widget matches the need, but is much less visual and therefore less powerful.
Connectez-vous pour publier, suivre du contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
