It would be nice to be able to copy or assign the subtype definition from one feature class to another similar to a domain. if you have 2 feature classes that use the exact same subtypes it seems an unnecessary extra task to enter the information twice and can also lead to mistakes.
Hi There, I've faced the same issue while working on a project, So, I've developed a python script toolbox to solve this issue.It only takes 3 parameters:
you may find it in the following path Copy Subtype and an elaboration to the tool in the following link Copy Subtype between layers
Yes this is needed. Contingent Values can be exported and imported, but not Subtypes.
How to “import” and “export” values to the “Subtype”?
1. The command “Table to domain” and “domain to table” are used to transfer data from and to the “domain” of the geodatabase.
2. Why we don’t have a command that transfer data from and to the “subtype”?
This is very frustrating!
Could you develop this command please?
Connectez-vous pour publier, suivre le contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
