When I'm working in Pro and add a layer to a map through the Catalog (i.e. right click on it, select "Add to MapTwo"), it will helpfully insert it into the order depending on the type: polygons go under lines, lines go under polygons.
However, if I copy a layer from MapOne and paste it in MapTwo, it will insert it at the top regardless of the type. While I can manually reorder, this is a tedious way to spend my time, particularly if MapTwo has a lot of layers already (and is therefore fairly slow to respond anyway).
