I would like to be able to apply a spatial definition query to a layer.I.e. Select features from this pointlayer that are within a feature from buildingpolygons.Defining a query must be as easy as it can be done in the Select By Location dialog.The result of the query is updated when features that are involved are modified.
Hi ramong, I believe you can accomplish this workflow by going to the Data Frame Properties > Data Frame > Clipping Options > Clip to Shape. Next click specify shape and in the Data Frame Clipping Dialog select Outline of Features and select your polygon layer. Next you can click exclude layers to exclude all other layers than the points and the output will be showing only the points inside the polygon.
### arcpyproduction EXAMPLE: arcpyproduction.mapping.ClipDataFrameToGeometry (data_frame, clip_geometry, {exclusion_layers})
This idea is a good start to a similar idea I had.
Instead of simplifying it to Clipping it would be awesome to allow definition queries that implement the arcpy Geometry api, or the SQL relational functions for ArcSDE.
Arcpy Geometry API:
Geometry—Help | ArcGIS for Desktop
Select features that are with 10 units to another:
where: SHAPE.distanceTo(other_table.SHAPE) = 10
Select features contained in the other:
where: SHAPE.contains(other_table.SHAPE)
SQL Relational Functions:
A quick tour of SQL functions used with ST_Geometry—Help | ArcGIS for Desktop
For example, select features that touch another:
Where: SHAPE@.ST_Touches(other_table.SHAPE@)
features that are equal to another (geometrically):
Where: SHAPE@.ST_Equals(other_Table.SHAPE@)
While I agree that such functionality would be handy, it does come with some risk. Spatial predicates are much more expensive than other predicates in DBMSs, and that is true when spatial indexes exist and are well tuned. If data sets either don't have spatial indexes, don't have them well tuned, or the DBMS chooses not to use them; well, the performance can be downright miserable.
Given there is a very real chance the performance of a spatial predicate will be quite poor, the software maker takes a beating for something they have little control over. What if a spatial predicate takes 2+ seconds to execute, possibly even 5+ seconds? Every time a user goes to zoom or pan, the screen just hangs for protracted periods of time. What if a map service is made out of that layer, how will that look to people consuming the service?
I can understand the desire for such functionality, I just think there is too much risk involved for Esri. Over time, the risk may diminish and make it more feasible, but I don't see it happening in the near term. That said, if one is working with enterprise DBMSs, then some of this functionality can be implemented at the storage level and brought into ArcGIS.
Also, clipping clips labels. Can look awkward.
While this can be achieved by using a normal definition query and utilize the used RDBMS spatial capabilities, it will however require disabling the standardized queries on the ArcGIS server to be able to spatially filter against a map service.
Providing such function by ArcGIS would be much cleaner.
This workaround does not limit the data in the database. It only limits what is drawn in the clipping extent.
I understand performance is a problem, but would it be possible to cache the selection set? E.g., You open the map and the layer with the spatial query grabs an up-to-date snapshot and caches it (or a portion of it, like Feature Cache in ArcMap) and remains static for the rest of the session or until the user chooses to manually refresh. This wouldn't work for constantly changing data, but it seems like it would work fine if the data only needs to be refreshed daily or weekly, and it's being used as a reference more than for active editing. Maybe that's too big of a caveat to bother explaining or implementing, but I think it would be worthwhile.
I see what you are getting at, and it isn't a bad idea, but it comes with risks as well. Caching addresses some aspects but introduces new issues that either need to be mitigated or documented and communicated to users. As good as documentation may be, we know most users take a cursory look if they bother to look at all. When new functionality performing well depends on numerous fine-print details that few will read or understand, users start complaining "it doesn't work" whether it is warranted or not.
Working with large eGIS datasets, I often find myself working with only a subset of the data in a feature class, generally in a specific part of the province. Harvest data is tied spatially to clients in "districts" and, depending on the task, I either export/clip the subset of harvest data into a new layer or run a layer query to narrow my search and reduce how much is displayed on the map. The former is an extra step and increases the number of intermediate layers to manage (which I try to keep to a minimum), while the latter is limited to tabular queries based on attribute data. 90% of the time, I use both together because I need to query the data over a specific area (clip) and over a specific time period (layer query).
I would LOVE if we could have both steps incorporated into one, i.e. by having "Select by Location" built into Layer Queries, combining spatial and tabular queries together. That is the idea I am suggesting.
@Anonymous User
I have two questions for you:
1. is your data stored in an enterprise database or file gdb?
2. >> Harvest data is tied spatially to clients in "districts" << are these district polygons coming from a separate Feature Layer?
Hello!
1. The Harvest data can come from either a gdb or enterprise database, usually eGIS.2. Yes, the polygons are in a separate enterprise database layer.In retrospect, I realize that I could easily create a model and ultimately my own tool for this; it is but one of many different scenarios where I have wished that ArcGIS would enable spatial and tabular queries. Sometimes I need to conduct multiple spatial and tabular queries on 2 or more eGIS/gdb layers before I can narrow down my search and begin working. This scenario is the simplest I could think of to describe my idea.Thanks,Ellie
hi @Anonymous User,
As you see, after @KoryKramer merged your post here, we don't have any out of the box capability at this point.
For now, I can give you a workaround and it will ONLY work if:
Steps to filter out features from layerA using feature(s) from layerB
The syntax provided below are for SQL Server. The STIntersects() function syntax will be different on PostgreSQL or Oracle or other databases.SQL#1
objectid in (select DS-A.objectid from DS-Ainner join(select shape from DS-Bwhere aField = 'aString_Value' ) aon a.shape.STIntersects(DS-A.shape) = 1)
SQL#2
exists (select 1 from DS-B a where aField = 'aString_Value' and a.shape.STIntersects(DS-A.shape) = 1)
Here is animation showing how I did that on my side:
I have a quick question regarding this:
I am trying to display this feature layer in ArcGIS Online Map Viewer. I only want to show the points in a certain county. As the data does not contain a county field, is there any way to do it in definition query other than typing the IDs of individual features?
https://idpgis.ncep.noaa.gov/arcgis/rest/services/NWS_Observations/ahps_riv_gauges/MapServer/0
Boyang
Hi @Boyang_Wang It sounds like your question is about how to accomplish that working in the ArcGIS Online map viewer. I would recommend posting a question to https://community.esri.com/t5/arcgis-online-questions/bd-p/arcgis-online-questions
@KoryKramer Sorry I did not realize this was a Pro forum. I do want to ask this question in Pro as well. For a map service with query enabled but export disabled, how do I display a subset of features in a given geographical area?
Thanks!
@Boyang_Wang
Unfortunately this is the supported at this point. Please up vote this idea as it appears important use case for you.
@JeffThomasILM
Regarding your comment about caching:
I have a related idea here: Control caching settings for better performance in event layers & query layers
Alternatively, running a scheduled job to precompute a field or a related table might work in some cases: What levels of the ArcGIS Enterprise stack support scheduled jobs?
Regarding @JoshuaBixby’s valid concerns about spatial query performance:
If anyone comes across this post and wants to set up a spatial definition query themselves on an EGDB FC, using spatial database functions like @TanuHoque suggested, then there are mechanisms in some DBs that can help with precomputing those expensive operations. For example, Oracle SDO_Geometry has function-based spatial indexes. They’re pretty tricky to set up so you might want to get your DBA to do it for you. But they do work and make spatial queries as fast as querying a FC/table. And they don’t require any extra database privileges other than CREATE INDEX, which you would have OOTB in the data creator role. If you know you’ll be performing the spatial query often, then function-based indexes might be worth the trouble.
I don’t know if other enterprise databases offer similar functionality or not. I think SQL Server has something called Indexed Views. But I don’t know if that helps in this case. File geodatabases don’t have equivalent functionality, that’s for sure. I’d be surprised if mobile geodatabases/SQLite did.
[removed and cleaned up in a later comment]
@RobertKlein3 Regarding your comment:
…would it also make sense to expand the functionality to turn any selection subset into a definition query, and retain that definition query once you clear selected features?
You might find this idea interesting: Selection to Definition Query
And it looks like there is Python workaround: Creating definition query from selected features using ArcGIS Pro
You can also just do it with a few lines of code. This has the advantage over the make layer from selected feature, in that you can see the query definition.def qdef_selected_features(lyr): desc = arcpy.Describe(lyr) # Get a semicolon-delimited string of selected feature IDs fid_list = desc.FIDSet.split(";") # build the query definition query = '{} IN ({})'.format(desc.OIDFieldName, ",".join(fid_list)) # apply the query definition back to the layer lyr.definitionQuery = query
I suppose it's worth noting that this idea wouldn't work for file geodatabases, since FGDBs don't have spatial SQL functions in the database (unlike enterprise and mobile geodatabases).
I talk about an alternative idea here:“Select By Location” Feature Layer — Spatial query that is fast, easy, modifiable, and refreshableThat idea is based on ArcObjects, so I think it would work for all datatypes, including file geodatabases.
One thing to keep in mind:
With Select By Location in ArcGIS Pro, the tool only has one row in the attribute table per feature. So if I run this Select By Location, it simply selects the features (1:1):
3,800 selected of 3,904
But with a spatial SQL operation like this:
--Oracle 18c, SDE.ST_GEOEMTRY SELECT r.* FROM road_row_st_geom r, --cross join strln_st_geom s WHERE sde.st_intersects (r.shape, s.shape) = 1 ORDER BY r.objectid
...it produces rows with duplicate objectids, whenever the polygons in the first FC intersect multiple lines in the second FC.
That's a typical difference between ArcGIS Pro vs database queries. ArcGIS usually performs only does 1-to-1 or 1-to-first queries. Whereas databases queries will propagate duplicate rows via the join.
10,614 rows selected.
I often forget about that quirk.
But I suppose, now that I think about it, if Esri were to implement the Spatial Definition Query idea, they'd do what they always do: only perform a 1:1 selection. So the quirk I mentioned above wouldn't be an issue for the user.
If I were to mock up the 1:1 logic in an Oracle query, it might look like this:
SELECT objectid FROM (SELECT r.objectid, row_number() over(partition by r.objectid order by r.objectid desc) rn FROM road_row_st_geom r, strln_st_geom s WHERE sde.st_intersects (r.shape, s.shape) = 1 ) WHERE rn = 1 ORDER BY objectid
3,879 rows selected.
But I doubt ArcGIS Pro uses that syntax. It might use some sort of generic ANSI SQL subquery or something like that?
It's interesting that Select By Location selected 3,800 rows. But my Oracle SDE.ST_GEOMETRY query selected more rows: 3,879. I wonder why there's a difference?
I did a related test (Oracle 18c):
Select road right-of-way polygons (~3,000) that have at least one intersecting point (road midpoints; ~3,000). Only select one row per polygon; I want a unique list of polygons that intersect at least one point.
1. ArcGIS Pro Select By Location tool (processes in RAM): 1 second
2. SDO_GEOMETRY database query: 10 seconds
SELECT poly_objectid, pnt_objectid FROM ( SELECT poly.objectid as poly_objectid, pnt.objectid as pnt_objectid, row_number() over(partition by poly.objectid order by null) rn FROM polygons poly CROSS JOIN points pnt WHERE sdo_anyinteract(poly.shape, pnt.shape) = 'TRUE' ) WHERE rn = 1
Related (uses different data): Select polygons that intersect points and a parallel post here.
3. SDE.ST_GEOMTERY database query: 50 seconds
SELECT poly_objectid, pnt_objectid FROM ( SELECT poly.objectid as poly_objectid, pnt.objectid as pnt_objectid, row_number() over(partition by poly.objectid order by null) rn FROM polygons poly CROSS JOIN points pnt WHERE sde.st_intersects (poly.shape, pnt.shape) = 1 ) WHERE rn = 1
It surprises me that my mediocre office computer with ArcGIS Pro —> Select By Location (processes in RAM) out-performs enterprise databases so spectacularly. Why are databases so bad at spatial queries?
Related:
In the old ArcMap docs, there are some examples of manually writing SQL spatial definition queries:
Workflow: Use SQL with existing feature classes (scroll to the bottom of the page)Create an expression to identify the particular features in the layer you want to display. The following queries find all the buildings within 25 meters of a water main. Type the expression appropriate to your DBMS in the Layer Properties Definition Query box.For Oracle:objectid IN (SELECT b.objectid FROM BUILDINGS b, WATER w WHERE w.watertype = 'MAIN' AND sde.st_intersects (b.shape, sde.st_buffer (w.shape, 25)) = 1) For PostgreSQL:objectid IN (SELECT b.objectid FROM buildings b, water w WHERE w.watertype = 'MAIN' AND sde.st_intersects (b.shape, sde.st_buffer (w.shape, 25)) = 't') For Db2:objectid IN (SELECT b.objectid FROM BUILDINGS b, WATER w WHERE w.watertype = 'MAIN' AND db2gse.st_intersects (b.shape, db2gse.st_buffer (w.shape, 25)) = 1) For Informix:objectid IN (SELECT b.objectid FROM buildings b, water w WHERE w.watertype = 'MAIN' AND st_intersects (b.shape, st_buffer (w.shape, 25)))
That requires manual coding. So it's not the same as this idea. But is still interesting.
The subquery approach looks useful. It solves the problem where the inner query might propagate duplicate rows via the join. Although it might not be the most efficient approach. EXISTS might be more efficient in some cases:
IN vs. EXISTSThe IN clause scans all records fetched from the given subquery column, whereas EXISTS clause evaluates true or false, and the SQL engine quits the scanning process as soon as it has found a match.
IN vs. EXISTS
I will like to select by coordinates my layers.
Connectez-vous pour publier, suivre du contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
