It would be useful if the validation of range domains was "on the fly" rather than having to select all your features and then validate features under the editor toolbar. Surely the time taken to set up the domain and to then validate is longer than to select by attributes of those invalid range values?It seems that all the validation does is select those invalid values anyway.
In ArcGIS 3.1, Range Domains are validated on the fly in the Attribute pane. When inputting a value that falls outside the assigned domain, the use receives the below warning, and the attribute edit is not able to be applied to the feature until the invalid value is corrected.
Connectez-vous pour publier, suivre le contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
