ArcGIS custom toolbox which uses a python script, for updating a mass amount of field aliases at once, using a list of field names and corresponding aliases input by user.
Let’s say you have an ArcGIS feature class or table with a bunch of cryptic, abbreviated field names, and you want to add aliases to make them easier to understand. Let’s say you also have a list of field names and corresponding aliases that you have prepared in Excel or whatever. All you need to do is save that list as a CSV file with the field names in the first column and aliases in the second column. Then run this tool. The only inputs required are the feature class and the CSV file.
