The interlude... An example of searchcursors and their array rootsCurses at cursors... pretty well a regular occurrence on this site. People love them and love to hate them.
They try to nest them, and nest them within 'for' loops and 'with' statements with calls that sound poetic ( ... for row in rows, with while for arc thou ... )
There are old cursors and new cursors (the da-less and the da cursors). Cursors appear in other guises such as the new, and cleverly named, 'arcgis' module (digression # 1 ... really? something else with arcgis in it! Who is in charge of branding).
Perhaps cursors are cloaked, in other arcpy and data access module methods (ie. blank-to-NumPyArray and NumPyArray-to-blank). Who knows for sure since much is locked in arcgisscripting.pyd.
Sadly, we deal in a work of mixed data types. Our tables contain columns of attributes, organized sequentially by rows. Sometimes the row order has meaning, sometimes not. Each column contains one data type in a well-formed data structure. This is why spreadsheets are purely evil for trying to create and maintain data structure, order and form (you can put anything anywhere).
| The interlude... An example of searchcursors and their array roots |
in_tbl <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"C:\Git_Dan\arraytools\Data\numpy_demos.gdb\sample_10k"</SPAN>
sc <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>in_tbl<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># the plain searchcursor</SPAN>
a <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>in_tbl<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>_as_narray<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># using one of its magic methods</SPAN>
b <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>TableToNumPyArray<SPAN class="punctuation token">(</SPAN>in_tbl<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># using the cloak</SPAN>
np<SPAN class="punctuation token">.</SPAN>all<SPAN class="punctuation token">(</SPAN>a <SPAN class="operator token">==</SPAN> b<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># True ..... everything is equal .......</SPAN>
sc<SPAN class="punctuation token">.</SPAN>_dtype <SPAN class="comment token"># .... here are the fields and dtype in the table ....</SPAN>
dtype<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'OBJECTID'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'<i4'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">'f0'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'<i4'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">'County'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'<U4'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Town'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'<U12'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Facility'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'<U16'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Time'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'<i4'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Test'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'<U24'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
sc<SPAN class="punctuation token">.</SPAN>fields <SPAN class="comment token"># .... just the field names, no need for arcpy.ListFields(...) .....</SPAN>
<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'OBJECTID'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'f0'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'County'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Town'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Facility'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Time'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Test'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># ---- Some timing... 10,000 records ----</SPAN>
<SPAN class="operator token">%</SPAN>timeit arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>in_tbl<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="number token">153</SPAN> ms ± <SPAN class="number token">12.3</SPAN> ms per loop <SPAN class="punctuation token">(</SPAN>mean ± std<SPAN class="punctuation token">.</SPAN> dev<SPAN class="punctuation token">.</SPAN> of <SPAN class="number token">7</SPAN> runs<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">10</SPAN> loops each<SPAN class="punctuation token">)</SPAN>
<SPAN class="operator token">%</SPAN>timeit arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>in_tbl<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>_as_narray<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="number token">40.4</SPAN> ms ± <SPAN class="number token">970</SPAN> µs per loop <SPAN class="punctuation token">(</SPAN>mean ± std<SPAN class="punctuation token">.</SPAN> dev<SPAN class="punctuation token">.</SPAN> of <SPAN class="number token">7</SPAN> runs<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">10</SPAN> loops each<SPAN class="punctuation token">)</SPAN>
<SPAN class="operator token">%</SPAN>timeit arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>TableToNumPyArray<SPAN class="punctuation token">(</SPAN>in_tbl<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="number token">52.1</SPAN> ms ± <SPAN class="number token">9.32</SPAN> ms per loop <SPAN class="punctuation token">(</SPAN>mean ± std<SPAN class="punctuation token">.</SPAN> dev<SPAN class="punctuation token">.</SPAN> of <SPAN class="number token">7</SPAN> runs<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">10</SPAN> loops each<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN> |
If someone can explain why the plain searchcursor is slower than its dressed up (or down?) counterparts, I would love to hear about it
Back to the main event
Harkening back to the fields of mathematics, arrays are assemblages of data, in 1, 2, 3 or more dimensions. If an array of any dimension has a uniform data type, then life is easier from a structural and usage perspective (this is one reason why Remote Sensing is easier than GIS
... bring on the mail). We need to maintain an index which ties our geometry to our attributes so what goes where, and where is what, doesn't get mixed up (digression # 2... I am sure this isn't what the branders meant by The Science of Where but we can only hope)
Nerd Stuff
Enough with the boring stuff... bring on the code.
Some of this has been looked from a slightly different perspective in
Get to the Points... arcpy, numpy, pandas
We need some data to work with so... how about a square.
in_fc = r"C:\Your_spaceless_path\Your.gdb\square"
The 'Describe' objectThe 'describe' object does just that: describes an object, in this case a FeatureClass.
desc = arcpy.da.Describe(in_fc)<SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
In the newer arcpy.da module, the values can be accessed from a dictionary. A quick way to get the sorted dictionary keys is to use a list comprehension. If you want the values, then you can obtain them in a similar fashion.
sk = sorted([k for k in desc.keys()]) # sorted keys
kv = [(k, desc<K>) for k in sk] # key/value pairs
kv = "\n".join(["{!s:<20} {}".format(k, desc<K>) for k in sk])<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN></K></K>
Some useful keys associated with featureclasses are extracted as follows:
With appropriate snips in the full list
[..., 'MExtent', 'OIDFieldName', 'ZExtent', 'aliasName', 'areaFieldName',
'baseName', ... 'catalogPath', ... 'dataElementType', 'dataType',
'datasetType', ... 'extent', 'featureType', 'fields', 'file', ... 'hasM',
'hasOID', 'hasSpatialIndex', 'hasZ', 'indexes', ... 'lengthFieldName',
... 'name', 'path', ... 'shapeFieldName', 'shapeType', 'spatialReference',
...]<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
The Cursor object
A cursor gives access to the geometry and attributes of a featureclass. It is always recommended to use the spatial reference when creating the cursor. Historically (fixed?), if it was omitted, geometry discrepancies would arise. This information can easily be obtained from the describe object from the previous section.
SR = desc['spatialReference'] # Get the search cursor object.
flds = "*"
args = [in_fc, flds, None, SR, True, (None, None)]
cur = arcpy.da.SearchCursor(*args)<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
See what it reveals...
dir(cur)
['__class__', '__delattr__', '__dir__', '__doc__', '__enter__', '__eq__',
'__esri_toolinfo__', '__exit__', '__format__', '__ge__', '__getattribute__',
'__getitem__', '__gt__', '__hash__', '__init__', '__iter__', '__le__',
'__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__',
'__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__',
'_as_narray', '_dtype', 'fields', 'next', 'reset']<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Individual properties are:
cur.__class__
<class 'da.SearchCursor'>
cur.__class__.__mro__
(<class 'da.SearchCursor'>, <class 'object'>)<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
The search cursor inherits from 'object' and the difference in their properties and methods offered by the da.SearchCursor can be determined as follows:
s0 = set(dir(mro[0]))
s1 = set(dir(mro[1]))
sorted(list(set.difference(s0, s1)))
['__enter__', '__esri_toolinfo__', '__exit__', '__getitem__', '__iter__',
'__next__', '_as_narray', '_dtype', 'fields', 'next', 'reset']<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
The cursor offers the means to process its objects.
cur.__esri_toolinfo__
['FeatureLayer|Table|TableView|Dataset|FeatureDataset::::', 'String::*::',
'Python::None::', 'CoordinateSystem::::']<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
This handy one
returns a numpy structured/recarraytype(cur._as_narray())
<class 'numpy.ndarray'><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
How about information on the attributes of in_fc (more about this later)
cur._as_narray().__array_interface__
{'version': 3,
'strides': None,
'shape': (0,),
'typestr': '|V36',
'descr': [('OBJECTID', '<i4'),
('Shape', '<f8', (2,)),
('Shape_Length', '<f8'),
('Shape_Area', '<f8')],
'data': (2044504703824, False)}<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
We got a glimpse of the field names and data types from the __array_interface__, but this information can be accessed directly as well.
cur.fields
('OBJECTID', 'Shape', 'Shape_Length', 'Shape_Area')
cur._dtype
dtype([('OBJECTID', '<i4'),
('Shape_Area', '<f8')]) <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Now, the gotcha's. We created our search cursor at the beginning and each record was cycled through until it reached the end. If we attempt to get its properties we may in for a surprise, so we need to 'reset' the cursor back to the start.
cur._as_narray() # try to get its properties, all we get is the dtype
array([],
dtype=[('OBJECTID', '<i4'), ('Shape', '<f8', (2,)),
('Shape_Length', '<f8'), ('Shape_Area', '<f8')])
Once the cursor is reset, the array values for the square are revealed with the appropriate data type.
cur.reset()
cur._as_narray() # reset to the beginning
array([(1, [342000.0, 5022000.0], 4000.0, 1000000.0),
(1, [342000.0, 5023000.0], 4000.0, 1000000.0),
(1, [343000.0, 5023000.0], 4000.0, 1000000.0),
(1, [343000.0, 5022000.0], 4000.0, 1000000.0),
(1, [342000.0, 5022000.0], 4000.0, 1000000.0)],
('Shape_Length', '<f8'), ('Shape_Area', '<f8')])<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
There is no automatic reset, so be careful. You can print the objects in the array in a couple of ways.
cur.reset()
for row in cur:
print(("{} "*len(row)).format(*row)) # print individual elements
1 (342000.0, 5022000.0) 4000.0 1000000.0
1 (342000.0, 5023000.0) 4000.0 1000000.0
1 (343000.0, 5023000.0) 4000.0 1000000.0
1 (343000.0, 5022000.0) 4000.0 1000000.0
1 (342000.0, 5022000.0) 4000.0 1000000.0<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Resetting the cursor, and print again.
cur.reset()
for row in cur:
print(row) # print the whole row as a tuple
(1, (342000.0, 5022000.0), 4000.0, 1000000.0)
(1, (342000.0, 5023000.0), 4000.0, 1000000.0)
(1, (343000.0, 5023000.0), 4000.0, 1000000.0)
(1, (343000.0, 5022000.0), 4000.0, 1000000.0)
(1, (342000.0, 5022000.0), 4000.0, 1000000.0)<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Of course since generator-like objects can be converted to a list, that can be done as an alternative, particularly if you have the memory and wish to deal with list objects instead.
cur.reset()
list(cur)
[(1, (342000.0, 5022000.0), 4000.0, 1000000.0),
(1, (342000.0, 5023000.0), 4000.0, 1000000.0),
(1, (343000.0, 5023000.0), 4000.0, 1000000.0),
(1, (343000.0, 5022000.0), 4000.0, 1000000.0),
(1, (342000.0, 5022000.0), 4000.0, 1000000.0)]<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
So if you know the data type of the components of the cursor, you can go to the ndarray in an indirect fashion.
cur.reset()
dt = cur._dtype
c_lst = list(cur)
np.asarray(c_lst, dtype=dt)
('Shape_Length', '<f8'), ('Shape_Area', '<f8')])<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
The ndarray can be viewed as a record array. Since the data type and structure remain the same, a 'view' of the array as a record array (recarray). Record arrays allow the user to slice the array using conventional array slicing or by object dot notation.
a = a.view(np.recarray)
a.Shape == a['Shape'] # check to see if slicing equals dot notation
array([[ True, True],
[ True, True],
[ True, True],
[ True, True],
[ True, True]], dtype=bool)<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Or more simply...
np.all(a.Shape == a['Shape'])
True
a.Shape # or a['Shape']
array([[ 342000., 5022000.],
[ 342000., 5023000.],
[ 343000., 5023000.],
[ 343000., 5022000.],
[ 342000., 5022000.]])<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
You can calculate the properties of the objects simply, but in the case of polygons, the duplicate start/end point should be reduced to a singleton. In the examples, the object's shape is obtained, then the desired property is derived on a column basis.
pnts = a.Shape[:-1] # get the unique points
cent = pnts.mean(axis=0) # return the mean by column
cent array([ 342500., 5022500.])<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
With some fancy work, and calling one of my previously defined array functions in the 'arraytools' module, you can do things like determine interpoint distances.
import arraytools as art
art.e_dist(cent, pnts)
array([ 707.11, 707.11, 707.11, 707.11])<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Which is correct given the square polygon's shape.
Another example, to demonstrate array functions. In the case of polygons, it is useful to have the first and last point (ie duplicates) retained to ensure closure of the polygon.
poly = a.Shape
art.e_leng(poly) # method to return polygon perimeter/length, total, then by segment
(4000.0, [array([[ 1000., 1000., 1000., 1000.]])])
art.e_area(poly)
Working with cursors
Cursors can access the columns in the tabular data in a variety of ways. One of the easiest to follow is to simply refer to the columns by the order in which they appear when they were retrieved. This is fine if one writes scripts in the same way. In the example that follows, the list of fields to be used with the cursor operations is defined as:
in_flds = ['OID@', 'SHAPE@X', 'SHAPE@Y', 'Int_fld', 'Float_fld', 'String_fld']<SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
When using the above notation, the position of the fields is used to reference their values. So you may see code that uses ' for row in cursor ' with row[0] being the feature object id (OID@) and row[3] being the value from an integer field (Int_fld). If you are like me, anything beyond 2, means you are finger counting remembering the python counting is zero-based. I now prefer to spend the extra time assigning variable names rather than using positional notation. You can see this in lines 12-13 below.
in_fc = r'C:\Folder\path_to\A_Geodatabase.gdb\FeatureClass # or Table
desc = arcpy.Describe(in_fc)
SR = desc.spatialReference
where_clause = None
spatial_reference = SR
explode_to_points = True
sql_clause = (None, None)
results = []
with arcpy.da.SearchCursor(in_tbl, in_flds) as cursor:
for id, x, y, i_val, f_val, s_val in cursor:
if id > 10:
do stuff
else:
do other stuff
results.append(... put the stuff here ...)
return results<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
arcgisscripting
arcgisscripting can be located in your ArcGIS Pro distribution once everything is imported (arcgisscripting.__file__). It is located in the installation path (substitute C:\\ArcPro for your Pro path, everything else is the same)
'C:\\ArcPro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\arcgisscripting.pyd'
Now importing arcpy, also imports parts of arcgisscripting and it also imports the geoprocessor from
C:\ArcPro\Resources\ArcPy\arcpy\geoprocessing\__init__
which imports _base.py which uses the Geoprocessor class as 'gp'
dir(arcgisscripting)
['ExecuteAbort', 'ExecuteError', 'ExecuteWarning', 'NumPyArrayToRaster', 'Raster', 'RasterToNumPyArray', '__cleanup__', '__doc__', '__file__', '__loader__', '__name__', '__package__', '__spec__', '_addTimeInterval', '_analyzeForSD', '_chart', '_convertWebMapToMapDocument', '_createGISServerConnectionFile', '_createGeocodeSDDraft', '_createMapSDDraft', '_createimageservicesddraft', '_getImageEXIFProperties', '_getUTMFromLocation', '_hasLocalFunctionRasterImplementation', '_listDateTimeStringFormats', '_listStyleItems', '_listTimeZones', '_mapping', '_ss', '_wrapLocalFunctionRaster', '_wrapToolRaster', 'arcgis', 'create', 'da', 'getmytoolboxespath', 'getsystemtoolboxespath', 'getsystemtoolboxespaths', 'na']
dir(arcgisscripting.da)
['Describe', 'Domain', 'Editor', 'ExtendTable', 'FeatureClassToNumPyArray', 'InsertCursor', 'ListDomains', 'ListFieldConflictFilters', 'ListReplicas', 'ListSubtypes', 'ListVersions', 'NumPyArrayToFeatureClass', 'NumPyArrayToTable', 'Replica', 'SearchCursor', 'TableToNumPyArray', 'UpdateCursor', 'Version', 'Walk', '__doc__', '__loader__', '__name__', '__package__', '__spec__', '_internal_eq', '_internal_sd', '_internal_vb'
References
Other discussions
https://community.esri.com/docs/DOC-10416-are-searchcursors-brutally-slow-they-need-not-be
More later...
