I have published a service to our Portal using one of our SDE layers from an enterprise gdb. I've created a webmap and added this service to it and configured the popup to display a custom list of attributes. When I click on the the polygon the popup display is correct in the webmap and app that I configured using the web appbuilder.
However, when I use feature search option to browse to a feature the popup changes the configuration of some of the attributes in the web app only. I have two fields in the popup where the data type is a double and they are set to display only 2 decimals through the webmap popup configuration settings. Using the feature search option in the web app returns the full 11 digits behind the decimal.
Is there anyway to have the web app return the same result as the web map?
Additionally, when using the feature search on the webmap in ArcGIS Explorer the feature search returns the search field as a float rather than the actual data type of Long Integer.
Any help would be greatly appreciated!#
