i have feature sever loaded on basmap i want to ask how to get object id when i clicked on map note i want to know if there are object or more on point i pressed or not then getall ids of all objects where is pressed language used (.NET)sorry for my English (i hope you to get what id mean)
Hi Issa,
Here is the link:
arcgis-pro-sdk-community-samples/Map-Exploration/CustomIdentify at master · Esri/arcgis-pro-sdk-community-samples · GitH…
404 error page not found
You should be able to use this sample: https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Map-Exploration/CustomIdentify . You have to change the SketchType to Point and use the logic in the OnSketchCompleteAsync method to get your feature classes and Ids.
I hope this helps, note: I fixed the bad link 😞
