I have a number of surveys which use the relevant functionality. I would like to transition some of them into surveys which allow for the updating of information now that the data has been collected. However, I am finding that if a relevant function is applied to a question the existing data is not populated. It appears to be a situation where the data from a feature is loaded into a survey where possible. If a relevant question is initial hidden the existing data will not appear even after the relevant criteria are met.
Specifically, I have a survey where the user can update the features of an asset for a number of reasons. If works have been carried out they are allowed to update some fields. If they are doing a principal inspection they can update all of the fields. However, I don't know what kind of inspection they are doing until they start... So, questions are initially hidden because the correct type of inspection has not been selected.
I don't want to show all the questions all the time as that removes a significant amount of elegance to the solution. Is there any way to get the survey to retrieve the values after the feature service has loaded from the inbox?
Thank you
