How would one go about changing the fill color of an SVG image used in a tool button or elsewhere in QML? In all of the examples I've seen, an SVG asset is referenced as a value or an image source property, and I've not seen a property to change the fill color for the SVG.
I suppose one could write some logic to open the SVG file, locate the fill color property (or properties in the case of a multi-path SVG) and change the color value but it seems like it should be a lot easier than that.
