Hi Guys,
Refer to this sample, if ShowVCS is true, it always select current Z value, how I can make current xy value to be selected by default? Uma Harano
arcgis-pro-sdk-community-samples/CoordSysDialog.xaml at master · Esri/arcgis-pro-sdk-community-samples · GitHub
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">mapping:</SPAN>CoordinateSystemsDetailsControl</SPAN> <SPAN class="attr-name token">Grid.Row</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>3<SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="attr-name token">SpatialReference</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>{Binding ElementName<SPAN class="punctuation token">=</SPAN>CoordinateSystemsControl, Path<SPAN class="punctuation token">=</SPAN>SelectedSpatialReference}<SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="attr-name token">ShowVerticalCSDetails</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>{Binding Path<SPAN class="punctuation token">=</SPAN>ShowVCS}<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">/></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
