At my organization we take environmental survey building. Each building is identified and many measuremenst are taken inside each building. I have created a form that is separated into two groups. The first group identifies the building that is surveyed, in a field named "Location" and the serial numbers of the equipment used. This first group is only filled out once and is non-repeating. The second group consists of the specific measurements that are taken inside the building that is mentioned in the first group. This second group is a repeating group and has many records per building.
When I export the data from the second group into an excel sheet, it would be very useful to have a defaulted column that is set to whatever the "location" field, selected in the first group.
