Good morning!
Using the ArcGIS Pro SDK, I have added to my project a File GeoDatabase. I need to add all the contents of that FGDB (7 Feature Layers and 1 Topology) into the map.
No problem with the Feature Layers. I have found a way to add them one by one:
Dim gdbDefinitions As IReadOnlyList(Of FeatureClassDefinition) = TryCast(gdb.GetDatastore(), Geodatabase).GetDefinitions(Of FeatureClassDefinition)()
Dim definitionsList As List(Of FeatureClassDefinition) = gdbDefinitions.ToList()
Dim path As String = gdb.GetDatastore().GetPath().ToString()
For Each fcDef As FeatureClassDefinition In definitionsList
Dim layerName As String = TryCast(fcDef, Definition).GetName()
Dim pathLayer As String = path & "/TOPOLOGIA/" & layerName
pathLayer = pathLayer.Replace("file:///", "")
pathLayer = pathLayer.Replace("/", "\")
Dim lyr As Layer = LayerFactory.Instance.CreateLayer(New Uri(pathLayer), map)
Next<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>That code only works for Feature Layers.
How can I add the Topology object into the map?
All of the objects are inside a Dataset, so another solution could be adding the Dataset into the map. But I haven't found any code snippet to achieve that, either.
Any help is welcomed! Thanks!
