Is there a way to use PULLDATA to zoom to the location for a record in pulldata? I want to read a barcode for an existing feature (sign) that has attributes in the media\*.CSV. I then want to geocode an XY location that is stored in the CSV file and then show it on the map in Survey123. A new survey record will be created at the new location. Can this be done?
Hi Jonathan,
You can access the Samples via Survey123 Connect as below:
Mikie
OK, I found it online but there is no option to download it. Can you enable download or attach the file so I can see how this was done? Thanks!
http://survey123.maps.arcgis.com/home/item.html?id=8767424aa9b745d98af62eab34808780
Thanks Claire, can you point me to exactly where I can find this sample? Where do I click to see it?
If I'm not mistaken, the exact functionality you describe is covered in the 'Calculate Location from CSV' sample provided in Survey123 Connect.
