Hi:
I'm making use of a Level 2 named user to edit a private feature service in an AppStudio app. How do I get rid of the watermark on the map? If I use the Lite License workflow I get a warning messages about my use of FeatureServiceTable applyEdits. Do I need to code something?
Matt
Solution:
Use the Runtime Lite key - this gets rid of the watermark. Then, once you log into ArcGIS Online in the app with a Level 2 named user, set the license level via code:
Connections {
target: securityPortal
onLoadStatusChanged: {
if (securityPortal.loadStatus === Enums.LoadStatusLoaded) {
var licenseResult = ArcGISRuntimeEnvironment.setLicense(securityPortal.portalInfo.licenseInfo)
Matt,
You would need to get the Runtime Basic License String from Esri Customer Service, and then replace the Runtime Lite License String in your app.
This can be found in the Advance section of the App Setting or appinfo.json
Thank you,
Erwin
I'm logging in as a Level 2 named user. I still need a Runtime Basic License String? The doc doesn't suggest that I need a license string. From the doc:
You need to include code in your Runtime app to enable a user to sign in (log in) to a portal and return license details associated with their Named User account.
What do I need to do with the returned license details in my code to remove the watermark?
