I created a new survey using a Feature Service and I am getting the following error when I try to publish the survey. I assume the error is asking me to add additional characters to the field name but if I do that it won't capture the data back to the correct field.
Error:
The Custom feature service submission url is not compatible with the survey (Field ODERCOMPLAINTNUMBER in NEO Gas Leak length is too short 20.)
Img attached:
Hi Jordan,
The error indicates there is a mismatch between the length of characters allowed to be submitted and what the existing feature service can support. When creating a survey from an existing feature service, Survey123 Connect will normally write those values in the bind::esri:fieldLength column. As Phil suggested, looking at the REST endpoint (also called service URL in the ArcGIS Online/Enterprise web UI) will provide the appropriate values.
What is the exact field name, type and length when you check the existing feature service rest endpoint? Can you take a screenshot of that?
Can you also please share a copy of your xlsx form so we can take a closer look. I notice that you have duplicate fields names in the name column, which is also not supported.
Phil.
Hi Philip,
I've attached our form below. Thanks!
Did you ever solve this? I am having a similar issue.
Mine says:
The custom feature service submission url is not compatible with this survey
(Field traptype in sitelocations length is too short 3
Hi Eric, I haven't found a solution. Hopefully someone will come across this post and help us.
