I created a survey (actually 2) that are defined to be used with two different languages. The enumerators will do the surveys in our local Rwandan language while the consultants approved the survey in English and will also analyse the data preferably in English, the report will also be done in English. Is there a way to visualize the results in survey123 in a different language than the default and to download the gdb maybe even with the different language?
If both is not possible, what would you suggest would be the best practise to enable the consultants to understand the questions and the answers?
