I can't seem to find an answer to my question anywhere on this forum. So I am looking for a way to customize which of the questions from the form/column from the results go into the file export (into Excel), as well as their order of appearance since I need the results to be "copy-pastable" into an existing database..
The closest thing I found is in "Data" from "My surveys", I can tick or untick certain columns, but it doesn't affect the export.Is there no way to select which columns to export?
As for the order of appearance, assuming the customization is possible in the first place, can I change the order in which they are exported? One of the answers which has to go last in the survey (it is the result of a few calculations) should go near the beginning of the export table.
Any ideas? If there is no way to do such things I could apply a makeshift solution through a different Excel, but I would prefer if the export could be as straight-forward as possible as I won't always be around the people using the survey.
Thank you very much!
Nikola
