I am trying to create a customized instance name for completed surveys and would like to show a label value rather that the name value for a select_one field. Is there a way to either return the label value directly into instance_name properties in setting or to calculate it into a text field or note?
This question was asked previously here: https://community.esri.com/thread/179622 but no solution was given.
Hi James,
The table-list appearance for the single-choice grid does not seem to work for survey connect. Also tried using field-list and label, list-nolabel to achieve similar single-choice grid layout and does not work
Hi Ruth,
The Survey123 web app supports the label and list-nolabel appearances, though it uses the table-list appearance for the single-choice grid.
Can ESRI add the following appearance options to survey 123 similar to enko.to. This will be a lot helpful to display question with similar answer
FYI: I just saw this post:https://community.esri.com/groups/survey123/blog/2018/11/01/understanding-dynamic-labels-in-survey123-for-arcgis , which states that "choice-name" is implemented since version 3.1.
Can't wait to try it out!
Hélène.
Hi Andrew,
Just to check, are you viewing the table in the Survey123 web page, or another application? If the former, we need to support HTML formatting in values.
James Tedrick
Here's what my Labels look like in AGO. If I remove the HTML formatting, it simply gives me plain black text.
Can you check the list definition of the feature layer in your content? You should be able to modify that now in ArcGIS Online - see Define attribute lists and ranges—ArcGIS Online Help | ArcGIS for more information.
Hello James Tedrick
I have the exact opposite issue. For some reason my survey is returning label values and not the name values from my 'select_one' list. This is problematic as I include HTML in the label to color code them:
Form:
Results are recorded as:
I found a workaround for this problem...
Create a "calculate" question with a pulldata function that read from a CSV that contain the same value of your choice list
Sheet survey
Sheet Setting
And yes...of course you have a little additional work to keep syncro between choice list and CSV....but in this way it works!!
Cheers
Stefano
Thanks James, Any idea on the time frame in which this might be implemented?
Hi Brent,
Currently the XLSform function that would support (choice-name) this has not been implemented in Survey123 yet- it's on our list of enhancements.
