In the ArcGIS Pro SDK documentation is mentioned, how you have to install a configuration.
I have some questions about this topic:
"RegisterAddin.exe" validates the configuration and copies it to the configurations' well-known folder: C:\Users\<UserName>\Documents\ArcGIS\AddIns\ArcGISPro\Configurations
Kind regards,
Max
Hi Max,
1. The RegisterAddin.exe will install the configuration to the default well-known folder which is "C:\Users\<UserName>\Documents\ArcGIS\AddIns\ArcGISPro\Configurations" You can define additional well known folders using the registry. Using this, you can define locations that are network paths, etc., accessible by multiple uses.
2. Yes, you can script the RegisterAddIn.exe. Here are the command-line flags:
3. Simply deleting the ProConfigX file is sufficient to "uninstall" it. If you are only using the default well-known folder, you could use the RegisterAddIn.exe with the "unregister" flag. For other well-known folders, you can simply delete the proconfigx file.
Thank you!
Uma
Hi Uma,
thanks for your answer.
Technically speaking, the Pro add-ins follow a “XCopy” deployment scheme. This means that developers (or installers, install programs, etc) can simply copy the add-in or configuration to the target folder “by hand” and it will “just work” – assuming that the well-known folder is known by Pro.
However, RegisterAddin.exe is useful in the following scenarios:
1. Building your add-in (and cleaning your add-in) – In visual studio, we defer to RegisterAddin which has all the logic required to determine the users default folder, extract the guid, make the subdirectory and so forth. The same logic is executed on clean – it removes the folder.
2. Double-click registration – this is handled through the file-type association. Developers can simply “double-click” the .addinx/.proconfigx and RegisterAddin will copy the add-in to its guided folder correctly.
3.Digitally Signed/Not signed – RegisterAddin alerts you to the presence (or not) of a signature. It gives you, the user, the opportunity to accept or not the installation of the add-in (because you do or do NOT trust the publisher)
4. EULA – if a distributor of the add-in includes a EULA then that is presented to the user.
