I am passing the below from Javascript as a parameter string via a GP Service.
Once I grab this in the python script I am trying to parse it....
I am trying to write variables for address, distance, and id for each record in a for loop....but having issues..thoughts?
<SPAN class="keyword token">for</SPAN> item <SPAN class="keyword token">in</SPAN> textstring<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'employees'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">:</SPAN>
varaddress <SPAN class="operator token">=</SPAN> item<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"address"</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"address: "</SPAN> <SPAN class="operator token">+</SPAN> varaddress<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
<SPAN class="keyword token">var</SPAN> text <SPAN class="operator token">=</SPAN> <SPAN class="string token">'{"employees":['</SPAN> <SPAN class="operator token">+</SPAN>
<SPAN class="string token">'{"address":"1520 Split Oak Ln, Henrico, Virginia, 23229","distance":"10", "id" : "1" },'</SPAN> <SPAN class="operator token">+</SPAN>
<SPAN class="string token">'{"address":"1341 Research Center Dr Blacksburg, VA 24060","distance":"9", "id" : "2" },'</SPAN> <SPAN class="operator token">+</SPAN>
<SPAN class="string token">'{"address":"816 W Main St, Danville, Virginia(VA), 24541","distance":"12", "id" : "3" },'</SPAN> <SPAN class="operator token">+</SPAN>
<SPAN class="string token">']} '</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
