I am unable to find information on how I can set maximum file size on photos when captured on Survey123 forms (without using IrfanView). Is there a way to set this constraint through Survey rather than changing the photo resolution from the app itself before capturing photos? Or perhaps what would be really handy is for Survey to resize (or rather downsize) the photo to the set max upon uploading.
Thank you
Hi Siew,
You can set the photo size in Connect via the Settings -> Images tab for each survey. By default it is set to medium:
Regards,
Phil.
HI Phil,
Thanks for pointing out where to set the sizes, with their corresponding sizes. 640 pixels are good default to have. Cheers SW
