Hi.
I am trying to understand how to work with the Suitability Score for parcels. Am I correct that to use this functionality I need to map the Suitability field to any field in my parcel file with a numeric value when I first load the file into Urban?
For example, if I have a field called "building_age" in my parcel file that has values from 1 to 10, I would map that field to the Suitability field in Urban. Then, using Urban I would use the slider to identify the parcels most likely to be developed based on the corresponding building age.
If my understanding is correct, does this also mean that only a single suitability category can be used unless the full parcel file is re-imported and a different attribute mapped to the Suitability field?
Dan
