I would expect the following code to essentially clone the top layer in the map. It does create a new featurelayer that points to the Uri, but calling SetDefinition has no discernible effect.
<SPAN class="keyword token">private</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">Test</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> def <SPAN class="operator token">=</SPAN> MapView<SPAN class="punctuation token">.</SPAN>Active<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">.</SPAN>Layers<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetDefinition</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> CIMFeatureLayer<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> conn <SPAN class="operator token">=</SPAN> def<SPAN class="punctuation token">.</SPAN>FeatureTable<SPAN class="punctuation token">.</SPAN>DataConnection <SPAN class="keyword token">as</SPAN> CIMStandardDataConnection<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> folder <SPAN class="operator token">=</SPAN> conn<SPAN class="punctuation token">.</SPAN>WorkspaceConnectionString<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Split</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'='</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>conn<SPAN class="punctuation token">.</SPAN>WorkspaceFactory <SPAN class="operator token">!=</SPAN> WorkspaceFactory<SPAN class="punctuation token">.</SPAN>Shapefile<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">throw</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Exception</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"test only works with shapefile layers"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> url <SPAN class="operator token">=</SPAN> Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Combine</SPAN><SPAN class="punctuation token">(</SPAN>folder<SPAN class="punctuation token">,</SPAN> conn<SPAN class="punctuation token">.</SPAN>Dataset <SPAN class="operator token">+</SPAN> <SPAN class="string token">".shp"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> fLayer <SPAN class="operator token">=</SPAN> LayerFactory<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateFeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Uri</SPAN><SPAN class="punctuation token">(</SPAN>url<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">.</SPAN>Active<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
fLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">SetName</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"my layer"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// name remains "my layer" Setdefinition has no discernible effect</SPAN>
fLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">SetDefinition</SPAN><SPAN class="punctuation token">(</SPAN>def<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
