I am trying to update a single entry in a feature class with new data from a work order. I have a feature class that contains all of the meter's in within an area. When the crew goes out into the field and change out a part they bring me a work order with the new serial number, model etc. Is there a way in model builder to select the single entry to be modified and update it with these new values? So far the only method I have come up with was to create a new feature class with the Select tool, then using the Calculate Field tool update each field. The problem has been getting this data back into the source feature class. I was trying to avoid a situation where I delete the old record and append the newly created one if possible.
