I need to track the changes in the data that have been edited in the surveys to later check them both to see what the changes were.
The workflow is as follows: a survey can be accepted or rejected by the supervisor, if it is rejected, a field is set in AGON so that it appears in the survey inbox 123, the field worker must correct it later with Surver123. However, we do not want to lose the information from the initial survey to have a record of the change and know what was done to that survey specifically
Any suggestions? James Tedrick
