When I download surveys into the Inbox my GUID data is not transferring down from the service. The survey has a GUID field that is calculated from a Collector URL Global ID parameter. The GIUD values are present in the service when I look at the data through AGOL. However, after refreshing the Inbox the GUID question is null. Why would the Inbox surveys not download the value from the service?
Thank you,
Kevin
