Darren Wiens; Dan_Patterson
When you set up a Domain Name on the Geodatabase and add the codes. I put the Field Type as a Text. My question to you when you go to the Feature Class Properties and all I can see that the subtype Field shows None; however, when I add the Name as a Field Name. I am wondering why the Subtype Field doesn't show the Name as a subtype ? Was it because I set it as a Text and it would not show it ? Is that correct ?
