Hi All,
I have a model that has a feature class to feature class inside of it with an iterate. As the first iterated item goes into the FC2FC it loads the field map with all of its fields. I need to drop all field map fields before each iteration of the FC2FC. Once before the tool starts iterating and then successively after each iteration. I cannot find anywhere how to delete the field map (bring all fields in input to the output).
David
David:
I apologize for dragging up a four year old post, but I'm having the same issue and I was wondering if you ever found a solution in model builder?
It looks like there are Python options for creating a new field map, but none that I'm aware of in Model Builder.
Thanks!
Here you go!
That clarifies it.
Can you post an image of your model schematic? I'm curious why the new fields would not be carried over. Seeing the model components may help in identifying what is going on.
The goal is to have the fields of the input file to make it to the output. Fields from the last iteration are staying in so when there are new fields it the field map does not contain them. If the field map was removed, it would populate with the newest inputs fields and forget about the time before.
Does that clarify?
To clarify what you want, is the goal to not have certain fields transferred from the input to the output?
Chris Donohue, GISP
