Hi Esri World,
I created a survey using Survey123 Connect and sent it out. Some users report that they get an error message that says: "String or binary data would be truncated. r/n the statement has been terminated" when attempting to answer a multi-line text question. I changed the character limit for this question from the default to 1000, but that doesn't seem to be helping. Any ideas?
Caitlin
Hi James,
In addition to Timna's points, from what I got, we cannot update the field lengths once the survey is publisher, correct?
BUT, here are a few questions:
Tks!
Couple of questions:
This would allow more flexibility for anyone who has to create surveys for clients/managers who have had a 'change of heart' in the direction they are taking after giving initial instruction (like that never happens LOL). Or is there a workaround by adding a new multiline text field in the XLSForm with the required increased character length specified in the bind::esri:fieldLength column? Or any other 'workaround'? Thanks.
Hi Caitlin,
That will set the size on initial publishing only- it can't update the size due to the limitation with ArcGIS Online.
Thanks James. What about the bind::esri:fieldType column in Survey123 Connect? This is where I changed the number to 1000 to override the default value of 250.
Unfortunately, modifying the length of text field storage is not capable within ArcGIS Online, so Survey123 cannot support it.
