I'm trying to create a progress dialog that shows a progress value from 0 to 100 %.
Doing some research I found out that ProgressDialog() with CancelableProgressorSource() is able to serve this. My current setting is as follows:
<SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">async</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">ComponentChangedHandler</SPAN><SPAN class="punctuation token">(</SPAN>Component selectedComponent<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">using</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> progress <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ProgressDialog</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Start Work"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> status <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">CancelableProgressorSource</SPAN><SPAN class="punctuation token">(</SPAN>progress<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
status<SPAN class="punctuation token">.</SPAN>Progressor<SPAN class="punctuation token">.</SPAN>Max <SPAN class="operator token">=</SPAN> <SPAN class="number token">100</SPAN><SPAN class="punctuation token">;</SPAN>
progress<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Show</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">await</SPAN> QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="keyword token">uint</SPAN> step <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">foreach</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> dateRange <SPAN class="keyword token">in</SPAN> dateRanges<SPAN class="punctuation token">)</SPAN>
<SPAN class="token function">DoSomeLongWork</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
step <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">;</SPAN>
status<SPAN class="punctuation token">.</SPAN>Progressor<SPAN class="punctuation token">.</SPAN>Value <SPAN class="operator token">=</SPAN> step<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> status<SPAN class="punctuation token">.</SPAN>Progressor<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
progress<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Hide</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>This way I'm getting a nice progress dialog with my dialog message and a bar animation spinning from left to right and back again. What I want is a progress bar filling up from left to right increasing percent progress by 10 in each iteration step.
What am I missing here?
