No results when I try to identify anything from the Meter feature class. It works for everything else in the current map, although if I create a new test map, it's not working for other layers in new maps either. So it may or may not have anything to do with that layer...? I'm looking to find out what kinds of things may cause this. It should be the last item on the list. Here is the config for the widget. I also attached the file if that's easier because this is long:
"identifylayeroption": "visible",
"identifytolerance": 5,
"defaultzoomscale": 1000,
"keepidentifyactive": true,
"returngeometryforzoom": true,
