So I am trying to use explorer on my android. But I haven't had much success. I am trying to log in and all it does is say failed to load map signing you out. I have no problem logging in and opening the same maps on my iPad. Is there a trick to it that I don't know about. I make sure that I go to "other sign in options" and type our organizations url. But I have had no luck getting signed in. Which is a bummer because I really want to try it out. Any ideas why I can't log in?
Kylie
Thanks for your help. Our default base map is set up so that our "streets" basemap. (One that I made of just our county streets. I did this to get around the whole LOD issue that esri has with its basemaps) I created a group called "basemaps" and I have that set as my Basemap Gallery. in the settings. I also checked "share the esri default basemaps to this group". I have had no issues opening this default basemap using AGO. and using the explorer for iPads. So not sure why the app for android won't allow maps to open with this default basemap.
I left out a word You need to be sure you have a valid *default* basemap configured. That means, outside of just the basemap gallery, that you have specified what the default basemap is for your organization. I've checked, and the steps Scott left should get you to the right spot: in "My Organization" click "Edit Settings", choose the "Map" tab, and make sure a basemap (that opens successfully) is set in the "Default Basemap" section.
If it does have one there, please let us know and we can look into this further.
Thanks!
what exactly does a valid basemap entail. The current basemaps I have set up for our organization works perfectly fine with explorer for iPad. So I am not sure what is considered valid or invalid. Basically I am using esri's base maps with one I created which is just a streets layer of our county that we operate in.
Hi Erik -- Did you make sure your organization has a valid basemap, as suggested by Scott in explorer for ArcGIS Android ?
I have noticed that it log in automatically (using the same credentials and maps you had open the last time). In case the map is not owned by you or it has been shared differently in the mean time, it probably does not allow access to it. Signing out is a little strange. You didn't change the password for the account, right?
