Hey rscheitlin
Having an issue with the identify widget where it will work on Feature Services but will not retrieve results when using a map service for the Identify Widget specifically. I have the necessary functions set up to allow for Identifying the map service but it will not work. I can just click on the map and retrieve results from the data in this map service and I can also use the Select Widget to retrieve results from the map service but not the Identify widget. As far as I can tell I am using Identify Widget version 2.4 and Web
